It is currently Tue Jul 15, 2025 5:02 pm
 Post subject: Re: H2 shift drum detent
PostPosted: Tue Sep 04, 2018 6:09 pm
Thanks H2RTuner, some sound advice when I get inside the cover shortly.
PostPosted: Tue Sep 04, 2018 7:51 pm
If you want, take pics and we can go over them
PostPosted: Wed Sep 05, 2018 9:53 am
I have forgotten, have you upgraded to a better clutch actuator?
PostPosted: Wed Sep 05, 2018 12:49 pm
Yes, I have the bronze/ steel type, forgot who sells it, seems to work well. Clutch does free nicely from a standstill, no 'clonk' into gear.
PostPosted: Wed Sep 05, 2018 1:23 pm
Good, just looking at all avenues to solve your problem. Let us know how the mod goes if you go in that direction.
PostPosted: Sun Sep 09, 2018 5:47 pm
Well I got inside the H2 today. I took a video here https://youtu.be/4Svf6dBb1Hc and it shows one of the problems, the shift arm stop pin is loose! Hoping that explains why this false neutral issue started happening, and it makes sense, it can overshift, with the stop moving. However, I still think the shift drum detent is weak. I used a dial torque wrench in the shift drum screw and rotated the drum with the torque wrench. It takes maybe 3 inch pounds to rotate the drum out of detent. I don't have anything official to compare that number to, but compared to other shift drums I have played with, the detent force seems really lame. For one, there is almost zero spring force once the arm is seated between the detent pins on the drum. In any case, I will order some 15mm OD by 3mm wide bearings and design and make a new arm, with more seated spring force.
PostPosted: Sun Sep 09, 2018 7:07 pm
I see your two issues. Stop pin loose, and detent spring too weak. The adjustable pin will help get the claw centered on the pins in the drum, so it centers and resets properly between shifts. New proper detent spring will also help. Looks like the claw spring is just fine.
You are on the right track.
PostPosted: Mon Sep 10, 2018 10:04 pm
I have a procedure I will outline to check the various adjustments, will post them tomorrow evening here.
PostPosted: Thu Sep 13, 2018 12:19 pm
Adjustment procedure PM'd to you, sir.
PostPosted: Fri Sep 21, 2018 7:47 pm
Have the new roller shift drum detent arm mostly drawn. It has a longer spring arm for more leverage and also higher seated tension. Ball bearing tip. This is drawn to scale of course, shows how lame the detent really is when there is also little spring tension, the tip does not seat between the pins very deep. I used the original 15mm tip radius for the bearing, higher seated pressure plus roller should sharpen the shifts up some. Mine stock is really mushy feeling.
