For those who wonders:
There are no UFO's made that fits the stock H2 carb. However, they make them for VM32 and 34. I know, because I have tried. BUT: There is enough material to remove from outer UFO edges to make them fit VM30, without messing up too much of the flow I think. But I do not know how good the mod will be as I have not tried them for the VM30.
But I have UFO's in 1 VM34 det that I have, and as said; I think it is very much possible making that mod also for VM30 sucessful. And I can assure you that the UFO has it's mission, THEY WORK!!!!
But they DO NOT make more peak power on full throttle as they led U to believe.
I can give 1 example of how you will feel the difference after they have been innstalled:
You got same power at f.ex 1/4 throttle opening as with f.ex 1/2 throttle opening without them, thus the throttle response is VERY much improved, and you WILL notoce the difference! You will also get rid of the characteristic H2 bogging (coming from lean, turbulent flow through venturi) at low rpm/load/throttle openings.
When in powerband, the response is just amazing
Jørgen
