It is currently Tue Jun 17, 2025 12:48 pm
PostPosted: Wed May 03, 2023 5:16 pm
I bought this wonderful 18" wheel on e-bay. I thought it was a Kawasaki hub with 6-bolt disc brake setup. The hub appears to have the same dimensions as my KH400 front hub. I tried searching for a 6-bolt brake disc and it looks like Kawasaki did not make one in this size. Then I thought maybe I could use the carrier from an H1 or H2. Too big, as you can see in the photo. I also realized that it doesn't have the screw holes for the conical chrome cover to fit on one side. Axle size seems to be the same as what I have on the KH400. I don't want to take the front wheel off the KH400 until I have an idea about how to approach this.
Possibly the easiest thing to do would be find an appropriate disc/carrier if the measurements are correct. If not, I measured the spokes and they appear to have the same length as what's on the KH400. Maybe I can use the KH400 hub with this wheel and spokes.
Anybody have an idea what bike this hub came from?
The E-bay seller doesn't know.
EDIT: I just counted the spokes - 36. Thus I can't use the KH400 hub with it.
