It is currently Tue Jul 08, 2025 5:38 pm
PostPosted: Mon Aug 18, 2014 10:47 pm
I'm trying to decide whether or not to brace a 72 H2 frame. Not sure what I plan on using for suspension at this point but not stock. This
is not a matching number bike so it will be built to ride, handle, and stop as best as a 72 H2 can with a lot of help. My first triple was the 75 Denco
replica that I built about 7 years ago and I braced the crap out of that thing. I worked really well compared to a stock late H1 and light years
better that a early H2. My question is, if I braced it like my old H1, well it be worth it? I followed this for my H1
My end result
PostPosted: Mon Aug 18, 2014 10:57 pm
You can if you want, and will be cornering a lot over 120 mph..... ;)
PostPosted: Mon Aug 18, 2014 11:08 pm
Hey John, you back from RB's already? I never ride a triple much over 90, but I do ride on a very twisty, tight mountain road. My last two 72's never held
a line in a corner or gave much feedback from the front. My first one with the 18" front worked much better so that is a must. Plan on using the Racetech
gold valve emulators and decent springs up front. Plan on getting one of those nice aluminum swingers for the back like on Cody's trick H1. If bracing will
help at all I'll give it a go.
PostPosted: Mon Aug 18, 2014 11:12 pm
Ron, be aware that the aluminum swing arm is longer than a '72's stock one.
PostPosted: Mon Aug 18, 2014 11:28 pm
Standard stuff really, Bronze bushes in the swinger, right springs in the front decent shocks 2" longer at least, good tires, 18 front. The al swinger is too long and not needed.......
PostPosted: Mon Aug 18, 2014 11:29 pm
Hey Jim, going to make it to deals gap one of these days buddy. Yes I think the aluminum one is to 74-5 specs if I remember correctly.
PostPosted: Mon Aug 18, 2014 11:31 pm
I had all that in both my H2's and they didn't work anywhere near as well as my 75 H1 that I braced the crap out of. My question is with all the standard fixes,
will bracing a frame help. :?:
PostPosted: Mon Aug 18, 2014 11:43 pm
Longer shocks make a huge difference, did you have those also?
PostPosted: Mon Aug 18, 2014 11:47 pm
Both H2's had 14.5 rear shocks
PostPosted: Tue Aug 19, 2014 12:13 am
H2 handling is not really frame related. (Argue away! :lol: ) We did a couple of things that your Illustration says - Run a mig (in the day) welder over the factory welds, and use beefier engine mount bolts. Way back when, we bought the steering stem in for 25.5 degrees rake, and put 1" into a slightly braced swing-arm, the memory is fading, but it was inconclusive...... The answer to handling is proper set-up, and bolt-ons, (shocks, etc.) I don't personally think frame-bracing is needed on a triple frame, given all the other things you can do. Raced H1/H2's for 10 years or so, and riding here is all tight, twisty, bumpy back roads. I reckon the triples handle fine, but time has caught up with them when you look at modern frames, suspension, etc, (of course!)
