It is currently Wed Jul 09, 2025 3:34 am
 Post subject: H1 carbs on an S3 or S2?
PostPosted: Wed Jul 30, 2014 6:54 pm
Anyone running these on their S2 or S3? I have a set of nice adapters that position carb exactly where the stock carb would be. I've got a bunch of H1 rebuildable carbs lying around. I need to move up in jet size and thought this might be a better idea. :?:
PostPosted: Wed Jul 30, 2014 7:13 pm
If you use H1 on S2/3 remember to jet up or holes can develop.
PostPosted: Wed Jul 30, 2014 8:40 pm
Burning holes in pistons? Why would stock H1 jetting be so lean????
:think:
PostPosted: Wed Jul 30, 2014 8:44 pm
Smaller pistons means less vacuum to pull fuel thru jets... so jets need to be larger to compensate.
PostPosted: Thu Jul 31, 2014 3:43 am
(Speaking for myself) you learn something new every day! :idea:
PostPosted: Thu Jul 31, 2014 6:19 am
Any pics Bill? Are they just modified H1 manifolds or has someone been very creative? :think: Been thinking about doing that carb swap myself, using the ones I bored out to 30mm. (after I "correct" them) When life gets out of the way of all my other plans (dreams?) :wtf:
PostPosted: Sun Aug 03, 2014 2:45 pm
Someone just hacksawed the round carb mount off of an H1 and hacked of the S3 carb mount portion and heli arched the two pieces. Voila..... I can send a pic if your interested in seeing them....
PostPosted: Sun Aug 03, 2014 2:49 pm
I used to think the stock air box lessened the reversion thus helping low end but I think it's just the fact that it's closed up a big more and slightly choking the carbs to draw more fuel. Smaller slugs draw less fuel.....duh. I think I knew that at one time but I forgot that and where the cake is hidden in the fridge. Thanks.
