It is currently Sat Jun 21, 2025 3:17 am
PostPosted: Mon Oct 19, 2020 11:56 pm
after reading the past posts on the Race Tech fork valves and springs i recently purchased, I have a few questions.
1. Drilled holes in aluminum rod w 10mm between O.D. of 3 sets of staggered holes, not 10mm CL to CL. Is it a structural mistake to drill in aluminum and are holes now too high?
2. What to do about 4-piece wafers with holes assembly; i am questioning their order/ direction as i lost original layout, and parts diagrams are poor. Also, it has been mentioned on this subject that they should be removed. What replaces them if removed?
Thank you
PostPosted: Tue Oct 20, 2020 12:28 am
Is this any help....... http://kawatriple.com/tips/forkmods.htm :think: You may have already seen it!
PostPosted: Tue Oct 20, 2020 7:02 pm
Thank you. Unsure about removing 4-piece holed assembly on rod shaft next to piston. That leaves11mm of open space; what to fill it with? I have Race Tech kit# S3002(their pick for H2's)springs and emulators & adapter w expanding ring for a snugger fit, w/ aluminum rods. Rods modified w 6 holes total, top rollpin modified for flow.
PostPosted: Wed Oct 21, 2020 9:29 am
If it's any help, I did this on my H2B... here
viewtopic.php?f=13&p=131863#p131863
