It is currently Sat Jul 05, 2025 7:11 pm
 Post subject: ex500 brake bolt size?
PostPosted: Mon Jul 24, 2017 12:27 pm
Doing the ex500 conversion. This is a basket case bike with no bolts. I looked on the conversion site and there are no bolt specs listed except the 10mmx125 thread size for the one hole. The other hole in the caliper is not drilled or tapped yet as it was an NOS unit so I want to make sure what to use. Any insight on this is appreciated and the video was good by the way on how to do this.
PostPosted: Mon Jul 24, 2017 1:39 pm
They're all M10x1.25 but I don't know the lengths. I had some fully threaded high strength bolts and cut them to length as I installed each one.
PostPosted: Mon Jul 24, 2017 4:46 pm
Thanks Jim. I need to order one of your regulators.
PostPosted: Tue Jul 25, 2017 12:20 pm
15mm length for the center bolt, 30mm length for the outer bolts for the record.
