It is currently Sun Jul 06, 2025 10:48 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Jul 21, 2012 11:13 am
oh i know... was thinking about it. but i figure w/the stock isolator gasket in there the expansion rate shouldnt be too bad. and the holes are not 'exactly' 8mm.... :lol:
PostPosted: Sat Jul 21, 2012 12:51 pm
refining....
PostPosted: Mon Jul 23, 2012 8:48 am
Damm that's a nice design. I've been watching the low end 3d printers for a few years now. They are really at the high end hobby level now and getting cooler and more affordable all the time. SO much potential....
There are 3 kinds of people in this world. The kind that can count and the kind that can't.
PostPosted: Mon Jul 23, 2012 12:24 pm
thanks steve, i appreciate it. I do plan on building my own printer over the winter. in the meantime, im lucky my office mate is letting me guinnea-pig on his.
PostPosted: Wed Aug 01, 2012 9:13 pm
got the first prototype test intake from kevin. his printer had issues and skipped on th ex axis but was good enough for a test fit. (cooling fans and 1.8 degree steppers will cure this)
its printed at 30% density hence why it looks so rough. it would def work but needs to be shortened a bit (can only do it about 1/2 inch more, maybe) . BUT everything clears nicely. you could def get away with angled unis on the outer carbs on the s2 frame. the intake/carb/reed is stock rd 250/350. length from stock s2 intake setup to this is 3". thats hair longer than i have on my h1 fwiw.
while it may not be theoretically optimal im thinking this will def work well.
dreaded neutral switch clearance. OK!
this is on a spare 73 s2 motor fwiw
PostPosted: Thu Aug 02, 2012 5:18 am
Looks fun !
I know you didn't paint those carbs.... :roll:
PostPosted: Thu Aug 02, 2012 5:49 am
.. rd350 carbs stock are painted black actually. those are 'original'
PostPosted: Thu Aug 02, 2012 8:21 am
VERY COOL
PostPosted: Sun Aug 05, 2012 11:45 pm
Would 30 or 32 flat slides work with the Yamaha reeds on a S3 ?????
PostPosted: Mon Aug 06, 2012 11:30 am
RODH2 wrote:
Oh, no - up means up, down means down, sounds like you will have to come here - we have better (twistier and bumpier) roads any way! (Thinks...... Deals Gap 2013, Hmmmm!!)
Up means up and down means down is such a classic quote for these bikes. I had no idea till i rode and owned my first one how nice that shift pattern is. :thumbup:
