It is currently Thu Jul 17, 2025 8:09 am
Post new topic Reply to topic  [ 528 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 53  Next
PostPosted: Sat Feb 11, 2012 9:48 pm
oxford wrote:
magee wrote:
useing two bathroom scales one under each wheel.
I read once that you could get an accurate weight using one bathroom scale by putting the front wheel on first, taking the weight, then putting the rear wheel on and adding the 2 together. Can anybody confirm that this will work?
I bet it's extremely close, I have heard the same thing. You could easily check, with a block of wood the same height of the scale, with and without it.
PostPosted: Sat Feb 11, 2012 11:49 pm
That's the key. Use something to bring the non-weighed wheel to the same height as the weighed one. Otherwise, tilting the bike will shift a little weight away from the scale.
PostPosted: Sun Feb 12, 2012 10:57 am
my wife wondered why I have TWO bathroom scales in the garage....at the same time having none in the house.... :lol:
350 is excellent Henry. Im shooting for 330, but know that 340 is probably more realistic when all is said and done.
Haven't touched the project in almost 2 weeks. Up to my eyeballs in "home improvements". :banghead
PostPosted: Sun Feb 12, 2012 7:15 pm
You will be good Cody. I have had 750 at 153kgs with fuel tank full , but racer with no lights. Also had 530 chain and heavy H1 rear hub. ( had premix though :) :) )
PostPosted: Sun Feb 12, 2012 7:19 pm
I just stand on the scale then pick up the bike. Works great. :lol:
PostPosted: Sun Feb 12, 2012 9:32 pm
Where do you get home scales that go to 1000 lbs. there Iron? Is that just a Lousiana thing?........ :lol: :e11 :lol:
PostPosted: Sun Feb 12, 2012 10:04 pm
Cody i went to a 520 oring chain, if i remember correctly it was a 4 pound weight savings
also used alloy rear sprocket
PostPosted: Sun Feb 12, 2012 10:30 pm
yep..
Im using a 520 conversion chain/sprockets with a Sprocket Specialist "titan tough" alloy rear...
PostPosted: Sun Feb 12, 2012 10:57 pm
They use it to weigh dem huge crawfish Iron catches.
PostPosted: Sat Feb 25, 2012 4:33 pm
Whelp... Its been about a month since Ive touched the hybrid project. My winter promise to my wife was that I would have the basement bath and laundryroom totally refreshed by the time the snow melted. Both of which should be finished in the next week. In any case, its all the down-hill/gravy work.
Sooooooo....Starting this week, I'm diving back in! A bunch of parts showed up in the last few weeks. Everything from tranny shims to crankshaft. The down time also allowed me to sit back and reassess a few early decisions. Sometimes you have to slow down and let it soak in, and Im glad I did as a few MAJOR changes were made which in turn really changed the entire "look/feel" of the project. I can now finally see the completed bike in my minds-eye.
A couple of "teaser" pics.......... 8-)
