It is currently Thu Jul 17, 2025 12:33 am
Post new topic Reply to topic  [ 528 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 53  Next
PostPosted: Fri Jan 13, 2012 6:52 pm
fyi.. an rd lc mono swingarm is pretty much a bolt into in an s series frame. i think the weight savings is around 4 lbs and the swingarm comes braced already. before you send er out to powdercoat.... just sayin....
PostPosted: Fri Jan 13, 2012 7:26 pm
Same width exactly? Do you know about pivot diameter and length (pivot to center of axle slot)????
all that said, aren't they a bit of rocking horse dung in the good ol' U, S, of, A?
PostPosted: Fri Jan 13, 2012 7:35 pm
a tad longer, pivot dia the same, a hair narrower at the pivot but can be shimmed in. I have one in the shed, can take measurements. they do come up. i got mine from this guy for 50 bucks.
check ebay canada
http://www.usa2strokers.com/forum/forum ... f-for-sale
PostPosted: Fri Jan 13, 2012 8:45 pm
I love Mini-Coils!
Bent the original upper air cleaner mount to vertical and ground in 3 "u-grooves" on top of the bracket for the coils to sit in.... Bolted them right into the existing holes!!!!!
Couldn't ask for a better spot and the first thing so far I didn't scratch my head forever trying to figure out where they were going........ looks almost factory.. :thumbup:
PostPosted: Fri Jan 13, 2012 8:50 pm
check ebay canada
thanks Mark...
One more important measurement if you dont mind!! The inside bore-diameter of the pivot tube.
I already drilled this frame to accept an H1 swingarm pivot bolt as the additional engine mount brackets required a longer pivot bolt... Instead of searching for a long enough replacement, I just drilled the holes as I have a plethora of H1 parts.
Sooooo. This also required me to install H1 swingarm bushings, and slightly narrowed inner spacer into the S-3 Swingarm. Ive already done all this work, so if I were able to just use H-series bushings in the RDLC swingarm, I would be golden...
If it turned out the RDLC pivot tube is of a different diameter, them Im sorta stuck and will just have to carry on bracing the existing arm.
PostPosted: Fri Jan 13, 2012 9:29 pm
16mm methinks its too late....
PostPosted: Fri Jan 13, 2012 9:34 pm
no!!!....the actual ID of the swinger tube (where the bushings are pressed into).. Not the axle diameter.
If the RDLC pivot tube has the same I.D., I can use H1/H2 swinger bushings and all associated parts.
PostPosted: Fri Jan 13, 2012 9:48 pm
ah. its the same as an s2 or s3 arm, that much i know. 28mm.
PostPosted: Fri Jan 13, 2012 9:54 pm
cool...cause the S-series is the same as the H!
PostPosted: Fri Jan 13, 2012 9:55 pm
call me and i can give some dimensions. im in the shop
