It is currently Thu Jul 17, 2025 9:40 pm
PostPosted: Sat Sep 29, 2018 3:19 pm
Like the ppg "Omni" paint vs. high temp engine paint in a rattle can off the shelf?
PostPosted: Sat Sep 29, 2018 4:16 pm
Normally it's spray lacquer that gasoline dissolves. The engine paints I've used like VHT and Rustoleum resist fuel spills.
PostPosted: Sat Sep 29, 2018 5:36 pm
VHT makes an epoxy frame paint in a can as does Krylon and maybe rustoleum. They would be the most resistive, but I still wouldn't use them on a motor where gas can spill.
PostPosted: Sat Sep 29, 2018 11:01 pm
Have had good luck with Duplicolor engine ceramic low gloss black(#1634). Resists gas and heat. Just follow the curing directions and it will work great for a spray bomb.
PostPosted: Sat Sep 29, 2018 11:08 pm
Thanks for the input guys!
Just want to put a coat of something on aluminum to seal it and keep from oxidizing, clear or some other color as engine will be mostly covered by body work.
8-)
