question about an S1 Transmission http://kawi2strokes.com/forum/viewtopic.php?f=14&t=9558 |
Page 1 of 1 |
Author: | wavehog33 [ Tue Dec 02, 2014 7:42 am ] |
Post subject: | question about an S1 Transmission |
The 2 collars on the S1 transmission that the end needle bearing rides in has an oil slot/groove on one side. Cant remember and tough to get a good pic of it, does that oil slot/groove face in toward the tranny or out toward the side covers? Thanks, |
Author: | Ja-Moo [ Tue Dec 02, 2014 11:23 am ] |
Post subject: | Re: question about an S1 Transmission |
It doesn't matter as much as the hole is offset so it changes the shim stack clearance. That is way more important...... |
Author: | Looney Cylinders [ Tue Dec 02, 2014 11:42 am ] |
Slots in bearing sleeves referred are to enhance oiling of the thrust washers, hence are normally installed towards gears. J |
Author: | wavehog33 [ Tue Dec 02, 2014 3:42 pm ] |
Looney Cylinders wrote: Slots in bearing sleeves referred are to enhance oiling of the thrust washers, hence are normally installed towards gears. J ja-moo, the locating hole for the dowel pin looks to be centered in the collar. J- facing the gears would mean towards the inside of the transmission towards the center? that is what I thought it would make sense for it to be I just can't remember. Thanks guys |
Author: | mraxl [ Tue Dec 02, 2014 3:50 pm ] |
Author: | Ja-Moo [ Tue Dec 02, 2014 4:21 pm ] |
I would measure, as I have not seen one with the hole centered. It is just something to look out for, as you don't want to start having trans problems. There is oil splashing around on either side anyway. |
Author: | wavehog33 [ Tue Dec 02, 2014 9:00 pm ] |
mraxl wrote: Ding ding ding!!! There is the pic I needed!!! Thanks!!!! |
Author: | III [ Tue Dec 02, 2014 9:45 pm ] |
When in doubt, Dale will bail ya out..... The resource pages are invaluable to say the least. |
