It is currently Mon May 13, 2024 6:17 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Jun 10, 2011 7:47 pm
Is it very durable?
Seems too good to be true in that the costs, and hastle factor are so low relative to even powder coating.
The photos look beautiful.
PostPosted: Fri Jun 10, 2011 7:53 pm
Jim C wrote:
Is it very durable?
That's how anodizing is done. Basically it makes a colored layer of aluminum oxide. (as in rust on iron) That is used on most sandpapers as it is super tough.......
PostPosted: Fri Jun 10, 2011 11:05 pm
Jim C wrote:
Is it very durable?
The finished job has a harder finish than the parent metal and will take quite a hammering. I do a lot of stuff this way for radio equipment bits and bobs, I miss the final boiling phase as I dont need a hard surface. An easier way is to use caustic soda to etch the surface and not worry about the battery charger ...works well but is less controllable, and Alkalines are far worse on the skin than acids. The thing is , with normal common sense, its safe to do, and any fumes are arguably no worse than breathing the paint fumes if you used that method. The depleted uranium bullet syndrome if you like. :lol: By leaving it as is, you will have a matt finish, polishing with metal polish will give a shiny finish. The easiest colours to get right are the black and dark green/blue. The lighter colours can appear blotchy, but practice` makes perfect! Ill post some pics of my stuff next time I do it.
PostPosted: Fri Jun 10, 2011 11:49 pm
starfire wrote:
Jim C wrote:
Is it very durable?
That's what I meant by any harsh chemical, use safety gear.
PostPosted: Fri Jun 10, 2011 11:54 pm
Just on a related subject... IF pistons were anodised, without the dye, it occurs to me that the microscopic etching on the surface would absorb oil and vastly improve the lubrication???
PostPosted: Fri Jun 10, 2011 11:58 pm
interesting idea!
PostPosted: Sat Jun 11, 2011 12:26 pm
Hydrogen embrittlement is an issue that commonly occurs with electrolysis/electroplating. Unless dealt with afterwards it could cause problems with stressed parts, such as piston.
PostPosted: Sat Jun 11, 2011 12:31 pm
Good point.
Proper heat treating afterward can contain that.
PostPosted: Sat Jun 11, 2011 12:55 pm
Last edited by Looney Cylinders on Sat Jun 11, 2011 2:42 pm, edited 1 time in total.
PostPosted: Sat Jun 11, 2011 12:57 pm
I "thought" hydrogen embrittlement was just in steel............ :?:
Teach me........
