It is currently Thu Oct 31, 2024 9:30 pm
PostPosted: Sat Sep 08, 2012 1:05 pm
Just finished a complete rebuild, the sprocket collar doesn't have a chamfer on either side, should I machine one in for a O-ring?
PostPosted: Sat Sep 08, 2012 1:26 pm
Make it the same as the later spacer fitted, with a chamfer at both ends (avoids installation confusion in the future). ;)
EDIT: I just looked at a 1969 spacer. There is a VERY small chamfer on each end. The later 500 spacer has a bigger chamfer on each end...
PostPosted: Sat Sep 08, 2012 2:22 pm
Had to take out my magnifier to see the chamfer. I think I will fix it........
PostPosted: Sun Sep 09, 2012 6:33 am
Now that you finished a complete rebuild for a 71 motor, what are your
plans for it?
PostPosted: Sun Sep 09, 2012 10:29 am
plans for it?
It is a customers motor........
