It is currently Mon May 06, 2024 4:49 pm
PostPosted: Mon Mar 05, 2012 8:15 am
Can anyone confirm the headlamp bracket config on H2B/C?
I took no pics :roll: and can;t remember how it goes.
Consists of each side according to Parts Manual:
a headlamp bracket, which has fork cover guide, washer and gasket below it. Above it a fork washer and 2 gaskets.
Parts manual a bit confusing but from my perspective looks like it should be ;
1/ Lower gasket on top of lower triple tree.
2/ Lower washer on top of gasket.
3/ Fork Cover on top of washer
4/ Then Headlamp bracket on top of lower washer
5/ Then upper washer on top of headlamp bracket
6/ Upper gasket on top of washer to fit under top triple tree. (Is the parts manual wrong should there be only one gasket on top and not two?)
TIA
PostPosted: Mon Mar 05, 2012 9:35 am
Is it same as this KH 250? Pic borrowed from Schurminators resto on the KH and S Series board.....
http://i779.photobucket.com/albums/yy73 ... 020559.jpg
PostPosted: Wed Mar 07, 2012 9:27 am
OK you can all stop answering now I have figured it out :eh:
It is the same set up as the 250 in the pic above so the parts manual is wrong, there should only be one top gasket per side.
H2C coming together nicely now.....pics soon.
