greens8 wrote:
For mraxi; I did run it this morning and it`s good, with the 90s,
I have been thinking about this quite a lot and when I woke this morning I was thinking that unless its confirmed that genuine Mikuni jets are fitted all this procrastination about jet size is purely academic as (
With the greatest of respect) the discussion from some members points of view is clearly based on 'previous' and I would think 'well documented' experiences of this model which I can only assume would have genuine Mikuni OEM parts fitted.
Through my own personal recent carburation experiences It could be that its just an apple and pears situation.
OEM (Mikuni) carburetor set up = Apples
greens 8 (Keyster or WHY ???) carburetor set up = Pears
Sure I admit that I edited my earlier post!! greens8 gave me the strong opinion that running 90's or less would be the WTG as to quote:-
"The best Ive had it before the rebuild was with 90s." I was thinking that fitting 85's and doing a plug chop would have conclusively proved one way or another if it was running rich or not. But after considering it for a while I thought that it better to err on the direction of caution so hence my suggestion to split the difference at 87.5's.
At the time I posted the original it was about 8.30 in the evening in Oz and at the time I edited greens8 would have most probably been in bed as I think it would have been 1.22am in Oz, I'm pretty sure that he wouldn't be feverishly ripping carbs apart and changing jets on the strength of this thread.
If it is only carburation conducting a 'Plug Chop' is the only way to go to sort jetting out, it really doesn't get any simpler than that!! otherwise its just
If the symptoms still persist I would then think that it must be electrical and so what Looney Cylinders has posted must surely be top of the list.
BTW how many miles have you covered since the rebuild?
