It is currently Sun May 12, 2024 9:48 am
PostPosted: Thu Jun 09, 2011 2:31 am
Here is one Ive nutted out...useful or not I have no idea.
The KH400 CDI is a nice compact unit and will directly replace the 4 boxes on the H1d and H2!
Wiring thus.
1) remove H2 units and discard
2) Fit the KH400 CDI to frame
3) connect the 3 WHITE wires in the harness, these are the signal coils to the BLUE/WHITE, RED/WHITE and GREEN/WHITE of the KH CDI.
4) Connect the three RED wires in the harness, these are the left/right/center ignition coils to the ORANGE, GREEN and BLUE of the KH CDI.
5) Connect the CDI BLACK/WHITE wire from the CDI to the BLACK/WHITE in the harness, kill switch.
6) Connect the CDI black wire to ground.
7) Connect the WHITE wire in harness, mag H/L coil to the RED from the CDI
connect the BLUE wire in harness to ground, mag coil ground.
The bike will now run
PostPosted: Thu Jun 09, 2011 7:30 am
Nice avatar, Starfire - I didn't know you flew with the Albanian Air Force..........................?
