It is currently Sun May 12, 2024 7:41 am
PostPosted: Mon Jun 13, 2011 7:08 am
someone banged some m8s into my pump then drilled them and tapped for the M6s, not ideal but seems to do the job.
PostPosted: Wed Jun 15, 2011 5:26 pm
yes youre right dale i'm trying, most holes are ok to helicoil. but the top centre outlet on the pump is a problem as the bore is same as plunger, so not sure yet how to go on. the locking part as JRD says will protrude into the bore. we are testing for strength on the helicoil with the ends snipped flush to the bore - it does make me nervous :shock:
keep you posted
PostPosted: Wed Jun 15, 2011 8:50 pm
Simon,
Get the locking style of heli coil in the 6mm-1.0 thread pitch with an overall installed length of 6mm/.250 ( it's 7mm/.274 to the bore ). As long as the hole is on size and drilled & tapped square it will be fine.
I'm a machinist and a lot of military applications call for helicoils right from the start in aluminum.
Jeff
PostPosted: Thu Jun 16, 2011 3:44 am
thanks jeff, my buddy is just using up helicoils 'off the shelf' as it were. i'll have a look next time i'm at his shop.
looking good. the biggest problem with trying to repair oilpumps is they all have the same problem, the tangs missing off the pulley or the top centre hole is stripped - what gives :roll:
PostPosted: Thu Jun 16, 2011 10:38 am
Time my British fiend...... Parts designed for a few years of use, still being used 40 yers later. Stripping because guys trying to re-use "one time only" crush washers, and over tightening when they leak, and many more "removals" that designed for. Same for the tabs, designed for 1 or 2 cable changes going through many more..........
PostPosted: Fri Jun 17, 2011 3:09 am
hey i aint no fiend :mrgreen: more why the top centre hole more than others?
PostPosted: Fri Jun 17, 2011 10:05 am
Wondered if you would catch that...... :lol: :lol: :lol: Aren't there less threads in the top center?
PostPosted: Fri Jun 17, 2011 10:27 am
Here's a related thread I started on a different board: http://www.kawasakitriplesworldwide.com/phpBB2/viewtopic.php?f=14&t=52547
Here are some excerpts:
Quote:
This evening I checked my oil pump banjo bolts and found one barely better than finger tight. When I tried to tighten it, it stripped. After making some measurements and doing some probing, I found about six more threads than the bolt could reach, before starting to block the internal passage. So I welded an extension on the banjo bolt, making it about 6mm longer, drilled the center, cleaned up the threads with a die, and re-assembled. It's plenty tight now, using the six threads farther in than the stripped ones.
Now I'd like to find a source of 6x1mm banjo bolts with a 6mm longer threaded part than the stock ones. It would make it very difficult to strip the others in the future.
Quote:
Frank wrote:
I'm assuming you've thought about the possibility of repairing the threads and discarded it?
I thought about it, and haven't discarded it, but tapping for a Helicoil or a similar thread repair insert requires getting every little chip out, so I probably need to remove the pump, at least. Also buy the kit, etc. When it stripped the other night, I just wanted to get it fixed quickly, without all the ordering, paying, tapping, cleaning, etc. Then when I saw all the good threads left, I thought that using longer bolts in the first place would probably prevent any others from stripping in the future.
Quote:
OK, here's the whole story. I removed all four stock banjo bolts from my pump, measured each hole depth and thread depth, made new bolts with safety wire holes in the heads, installed rubber seal type washers, and reassembled everything and wired it all in place. The safety wire gives me some confidence to just snug them up, but not worry that they will vibrate loose.
Outlet bolt hole closest to cylinders (R cyl): 8mm deep, fully threaded
Outlet bolt hole toward rear (L, cyl): 14mm deep, 9-10 threads to cross passage (1mm per thread)
Outlet bolt hole toward front (C, cyl): 14mm deep, 9-10 threads to cross passage
Inlet bolt hole: very deep hole, but threaded only about 2 threads more than stock bolt
So for the R outlet, I was able to get about 2 more threads engaged than the stock bolt. I had to use care not to make the bolt too long, as it would hit the pump's valve sleeve if it were.
For the L outlet and the C outlet, I was able to make bolts that engage at least 5 threads more than the stock ones did. The L outlet was the repair that I started this thread with.
For the inlet, I found my threads essentially stripped before I started. The bolt was not very tight, and when I turned it, it would not tighten. I took off the pump cover, which had its little tab broken off, but still in place (!) so I could see inside, and saw plenty of room for threads, but only two unstripped ones. I used a greased tap, and tapped it all the way through and cleaned all the chips out that the grease didn't catch (vacuum, rinse with WD-40, repeat a few times), made a bolt 5 threads longer than stock (full length of my blank bolts) and put it in. Then I TIG welded the tab back on the cover, which was quite a micro-welding job.
So (on my pump) to use a long bolt on the inlet to fix stripped threads required tapping deeper, which means you might as well install a Helicoil. The R outlet doesn't have enough depth to fix stripped threads with a longer bolt, but might be worth using one that's 2mm longer than stock to prevent trouble, although great care has to be used not to make it too long. The L and C outlets can take bolts 5mm longer than stock for a repair or strip prevention.
Since there is probably variation between pumps, and since this isn't a clear cut procedure, I don't want to get into making longer bolts for others. They might end up causing more trouble than they fix. But if anyone wants to do it himself, I'll be glad to send blank bolts, since I still have about 96 of my original 100 in the bag.
I still have plenty of plain bolts, in case anyone wants to make some extra long banjo bolts.
PostPosted: Fri Jun 17, 2011 9:52 pm
I may be a bit late on this subject but il put my 2 cent in.
Helicoils are a beautifull thing.
I stipped one pump outlet thread, so i helecoiled all four threads.
Use a 2D (2 x diameter long) helicoil on the inlet. (cant remember if you have too trim it)
Use 1D on the three outlets. My important point is the 1D is too long above the drum because they grow in lenght as you screw them in. So do one of the other two first and measure how much it grows, then trim the coil accordingly for the one on the drum.
Of coarse you have too strip the pump, so while you are there, replace all the O-rings, theyre all still available from Kawa except one outer seal which you can get from seal specialists.(viton)
Another important point...dont drink beer on assembly and look at exploded view in manual or fishe, because the ones i looked at show the drum the wrong way around :roll: youl ruin the o-ring trying :lol: Befor you realise its the wrong way round :lol:I allways stop important work after 5 stubbies, which usually gives me about an hour and a half in the garage!! I like too drink fast as well :lol: :lol:
I love helecoils :lol:
