It is currently Tue Apr 16, 2024 12:16 am
PostPosted: Sun Mar 11, 2018 10:41 am
Pulling the clutch because its slipping. Pics to follow
The old friction plate(left) is on what looks like phenolic and is thinner than the new friction plate(right). That could be why the clutch is slipping, maybe?
1974 Kawasaki KH400
2000 Suzuki Hayabusa
PostPosted: Sun Mar 11, 2018 2:30 pm
Where did you get the new corks?
Are the old ones just worn thin or on a thinner plate as you said the base looks thinner?
A nominal thickness difference may not be a big deal, as long as the throw is long enough
from the pusher, to separate them well.
You will likely get several opinions on what gear oil or ATF to run in the case.
That can make a difference on slipping clutches too.
New corks, sand down the metals well to clean them up.
If using new springs, be sure they fit in the wells OK.
Some have had to open the holes a bit for heavier springs as they can bind when
compressed and then they are slow to expand.
just some stuff to watch, I'm going to be adding my new Barnett corks soon yself.
Good luck
PostPosted: Sun Mar 11, 2018 3:51 pm
Ebc clutch. I use 90w in the transmission. Springs are good. Adjustment is correct.
Clutch is in. I had to file each side of the outer tabs on the friction plates to get them to slide onto the basket.
Now its like the clutch is pulled in. I can't turn the crank with the kickstarter or putting in gear and pushing bike. Maybe I didn't file the tabs enough? I'm done with this problem for today. I will try again next weekend.
GRRRRR!
1974 Kawasaki KH400
PostPosted: Sun Mar 11, 2018 7:10 pm
You might not have the clutch indexed properly..
PostPosted: Sun Mar 11, 2018 8:16 pm
The pressure plate will fit many ways, but there is only one way that is correct. I don't know where to find the picture though.
PostPosted: Sun Mar 11, 2018 10:20 pm
http://www.3cyl.com/mraxl/manuals/maint/section4.htm#assembly
PostPosted: Mon Mar 12, 2018 1:34 am
Since the friction plates are close to the same size some of the early enduro bike's are, save a couple of things, those in aftermarket manufacturer places sub in the enduro parts, and trouble occurs.
Check as others have indicated on the clutch pressure plate, then redo the release and cable adjustments, they don't sound correct, 90 wgt gear oil is just fine.
PostPosted: Mon Mar 12, 2018 1:58 am
That picture is for the H series, not the S
PostPosted: Mon Mar 12, 2018 4:34 am
Gee whiz, thanks for your input.
I was merely showing WHAT it was, not being model specific.
But your help is always nice to get John.
:roll: :roll: :roll:
PostPosted: Mon Mar 12, 2018 6:12 am
At bottom:
http://kawatriple.com/partid/clutch/clbasket.htm
