Mininmal wiring to run... http://kawi2strokes.com/forum/viewtopic.php?f=14&t=13184 |
Page 1 of 1 |
Author: | mizike77 [ Mon Nov 27, 2017 7:49 am ] |
Post subject: | Mininmal wiring to run... |
I would like to fire my project before breaking it back down for paint, polish, powder coat. I havnt heard either one of my H2 engines run yet. It was once wired up as a hill climber or drag bike, so CDIs and regulator are in a box with wires everywhere. What is the minimal wiring I can do to fire it? Also, when it goes back together for the final time Im only running a headlight w hi/lo , tail/brake light and a horn. No other lights. |
Author: | Ja-Moo [ Mon Nov 27, 2017 11:45 am ] |
Post subject: | Re: Mininmal wiring to run... |
Just the ignition wires from the stator to the boxes and coils. make sure you have a grounding wire for a kill wire, if the motors revs off on you. |
Author: | mizike77 [ Tue Nov 28, 2017 7:27 pm ] |
Ja-Moo wrote: Just the ignition wires from the stator to the boxes and coils. make sure you have a grounding wire for a kill wire, if the motors revs off on you. What about the regulator/rectifier? Will I cook the boxes without them? |
Author: | Jim [ Tue Nov 28, 2017 7:33 pm ] |
Connect the two yellow wires from the alternator together and insulate them, and you'll be fine. It sounds odd, but it reduces parasitic engine load and makes the alternator run cooler than leaving them open. It also prevents unwanted voltages on the CDI units. |
