It is currently Sun Jul 06, 2025 9:07 am
 Post subject: H2 part throttle problem
PostPosted: Sun Sep 10, 2017 11:28 am
Took the 72 H2 out for the first time in a couple of seasons, drained carbs last time it was ridden, fired up 4 kicks , idles well and pulls great full throttle but feels like it's not running on all 3 cylinders steady throttle until throttle is past 1/4 turn. Has Lakeland all in one unit, K&N pods and early Wirges chambers. Maybe pilots jets gummed up?
TIA
72 H2, 76 XLCH, 78 KZ1000, 99 ZRX, 04 120ci Fatboy
PostPosted: Sun Sep 10, 2017 11:29 am
That would be my first guess.
PostPosted: Sun Sep 10, 2017 11:56 am
Clogged pilots usually effect the idle, but always good to check.
PostPosted: Sun Sep 10, 2017 7:35 pm
Did some searching around the forum, pulled plugs, left and center seem ok but a little rich, right cylinder darker and wet, RH pipe smoking more heavily than other 2, checked trans fluid level, went from upper mark to lower mark on a 70 mile relatively hard ride. Think I found the problem?
PostPosted: Sun Sep 10, 2017 8:02 pm
Sounds likely.
PostPosted: Mon Sep 11, 2017 4:46 pm
What's the problem?
A bad seal?
72 H2, 75 H2C
PostPosted: Mon Sep 11, 2017 5:18 pm
The dropping of the transmission oil indicates the right crank seal is leaking. It can be changed without splitting the case halves, but it could mean there are more leaking crank seals, so it's probably a good idea to do a leakdown test on all of them.
PostPosted: Sun Sep 24, 2017 4:35 am
Thanks Jim for that info
72 H2, 75 H2C
