ufo's - can't get it lean enough http://kawi2strokes.com/forum/viewtopic.php?f=14&t=13035 |
Page 1 of 1 |
Author: | jason8887 [ Thu Aug 31, 2017 6:23 pm ] |
Post subject: | ufo's - can't get it lean enough |
I installed UFO's on some stock vm30's a couple of weeks ago. I cut the slides and inserts to have a 3.5 cutaway and I installed a 15 pilot jet. I couldn't get it to be lean enough (mix screws at 2.75 turns out) so I drilled a small hole in the main jet choke. I still couldn't get it to lean out so I tried soldering my pilots shut. I think it leaned out but then I couldn't get it to idle down lower than 1800 rpm and it surged like crazy when I took it for a test ride. So, I think I am going to give up on the ufo's and add some jb weld to my slides to get back to the 2.5 cutaway unless someone has some insight |
Author: | Hawaii-Mike [ Thu Aug 31, 2017 6:36 pm ] |
Post subject: | Re: ufo's - can't get it lean enough |
Surging is an indication of lean jetting. My VM30's were rich before and after UFO's. I went to O-4 needle jets and it fixed the problem. You can read more here: viewtopic.php?f=14&t=11141=h2+needle+jets&start=20#p125345 |
Author: | demus [ Thu Aug 31, 2017 6:42 pm ] |
Needle jet and needle play a big part even at idle and take off with those UFOs Surging is way too lean. Don't go for high idle adjusting the screws go for good takeoff and good idle rpm richen up the screws a bit and see what happens On the resource site is a good description of tuning with UFO they realy do change the rules of jetting How does it run in the needle? I would try a smaller needle jet those draw a lot of fuel between the needle and the needle jet Good luck. Running back to safe ground is a good choice too! |
Author: | jason8887 [ Thu Aug 31, 2017 6:58 pm ] |
so I should explain why I don't think I could get it lean enough with the UFO's: the bike would fire right up and idle high when it was cold, no choke needed at all. If i let it sit there for a minute or two idling it would slowly drop rpm, to the point that I had to turn the idle screw in to get it to stay running. Same results if i took it out for a ride right away: when I got back to the shop the idle would be way too low to stay running. Also, the plugs were very black and sooty, way too rich. So, the answer is probably somewhere between the #10 jets (I think I said they were #15's in my original post) and the closed pilots. I'm just not not committed to buying needles and more main jets. Thanks for the observations, I appreciate it |
Author: | jason8887 [ Thu Oct 05, 2017 3:22 pm ] |
I un-converted my slides a few weeks ago, changing my cutaway back to a 2.5 from the 3.5 I had when the UFOs were installed. Here's what I did: I cut a piece out of a soda can, applied some spray-lube to one surface, then wrapped it around my slide using a hose clamp. I made sure to get the piece of soda can flush with the bottom of my slide Attachment: IMG_20170907_142722947.jpg I then mixed up some jb weld and filled in the cutout, using the soda can to mold the jb weld Attachment: IMG_20170907_142807481.jpg Attachment: IMG_20170907_142640320.jpg
Author: | jason8887 [ Thu Oct 05, 2017 3:25 pm ] |
I then made a template using CAD that showed me where to cut to get back to my 2.5 cutaway. I taped that to my slide Attachment: IMG_20170907_152158361.jpg Attachment: IMG_20170907_152202092.jpg Then I cut the angle using a dremel. Attachment: IMG_20170907_154032797.jpg It turned out pretty well and the bike seems to relatively run well. I also ended up using #20 pilot jets also. Still trying to get rid of some of the surging on small throttle openings, mainly during decel. |
Author: | Jim [ Thu Oct 05, 2017 3:37 pm ] |
You didn't specify the throttle opening when you're having surging trouble, but you could try raising your needles a notch. I prefer getting good gas mileage to worrying about surging though. My H2 surged when I bought it, and shortly after that I learned how to avoid it with throttle technique and gear selection. Raising my needles a notch eliminates the surging I have, but it also drops it from 30 mpg to less than 25. |
Author: | Ja-Moo [ Fri Oct 06, 2017 12:08 am ] |
Get new pilots, you can't solder them and have them work correctly. Do't ask how I know. |
Author: | jason8887 [ Mon Oct 09, 2017 10:55 am ] |
Jim I had been getting less than 25 mpg out of my bike before/during my ufo experiement. If I raise my needles I get really bad bogging at cruising speeds on the highway. It essentially feels like it is dropping a cylinder randomly. If I lower my needles the bike feels really 'dry' and buzzy. I haven't put enough miles on it since taking the UFO's out to get an mpg reading so I am not sure if my current combination is helping in that department or not. Ja-Moo Not sure if your post was intended to be funny, I will take it that way though! |
Author: | Jim [ Mon Oct 09, 2017 12:18 pm ] |
You can move the needles in 1/2 steps (1/2mm) with shim washers under the clips. |
