It is currently Tue Jul 15, 2025 12:55 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Mon Mar 30, 2015 11:46 am
Ahh, the old discussion! I can set up a H2 properly, but I would run 2 hydraulic dampers if I could........!!. (And when I go FAST on the ZX10r, damper on full, and that thing handles a lot better than any triple!!!) :wtf:
PostPosted: Sun Jun 14, 2015 2:53 pm
Getting my 72 frame ready for the powder coaters. The stock damper bracket was repaired and didn't look safe so I made my own out of 1/4" bar.
This one should hold up for a while.
PostPosted: Sun Mar 06, 2016 6:12 am
Looney Cylinders wrote:
Simply re welding the original bracket/welding the corners is not the permanent fix.
The original Kaw cantilever design will continue to flex and fail again in time, probably at the edge of the repair weld (like sawracer's repaired/welded bracket did).
To fix it properly an additional stay rod needs to be added to triangulate the damper mount. This is what Kaw did with the additional bracket installed on the H1B. As such there is essentially no flexing/fatigue occurring during normal operation.
Can you explain a bit more, if you will, maybe pictures...??
Mine is cracked, so needs to be welded and/or reinforced as well...
1973 Kawasaki 750 H2A,
1969 Garelli Rekord 50cc,
1985 Ducati Mille MHR.
PostPosted: Sun Mar 06, 2016 10:21 am
The best fix I could come up with is just to remove the original and then use bar stock. I got into the habit of doing this
before I send the frame to the powder coaters or painters.
PostPosted: Sun Mar 06, 2016 10:34 am
Looks fine, but I need it to be fixed as it is right now, not going to powdercoat the frame or anything, as all looks good now.
Just some sort of weld, and a local respray is my goal.
PostPosted: Sun Mar 06, 2016 12:39 pm
I simply "box in" the stock bracket, by adding filler plates to the top and bottom of the mount welded to the mount and frame. Never had a problem after that. I, too, have run two dampers on one frame, just have to fabricate the mounts, install the damper.
PostPosted: Sun Mar 06, 2016 9:16 pm
I wish I had done that fix :)
1977 KH 400
1976 KH 250/350 rat bike
1971 KV 75
1976 KV 75
PostPosted: Tue Nov 22, 2022 4:50 am
Good to know of pattern failures.
Thanks for this.
I'll fab a little 12ga. triangular gusset, weld it in place when the opportunity presents itself.
WFO for 51 years
1974 Norton Commando 850 Roadster
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
2014 Rocket III Touring
