It is currently Sun Jul 06, 2025 3:11 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Sep 16, 2017 4:31 pm
Thanks for the help Jim and Moo! :D
“Jeff and Chris are THE MEN!”
RIP John E. Evans
PostPosted: Sat Sep 16, 2017 5:17 pm
Glad to help! I will stump for Jim. If you dont have his boxes yet, get em. Stock still is all failing.
PostPosted: Sat Sep 16, 2017 5:30 pm
The one that failed was Jim's box but it was 5 yrs old. Thank goodness I had my old stocker.
RIP John E. Evans
PostPosted: Sat Sep 16, 2017 5:33 pm
You sure it was a full five? Was it a rebuild, or a single box?
Edit: I found the information, it was a rebuild in early 2012. Send me an email please, so I can work something out to help.
PostPosted: Sat Sep 16, 2017 6:16 pm
Email sent to you Jim. :)
RIP John E. Evans
PostPosted: Sat Sep 16, 2017 6:41 pm
Got it. I'll get you going again, Evans.
PostPosted: Sat Sep 16, 2017 9:48 pm
Jim, does the too high voltage from the original voltage regulator end up killing the CDI boxes?
PostPosted: Sat Sep 16, 2017 11:00 pm
No, the ignition system is powered by magneto coils in the alternator, which are completely separate from the 12v system. An H2 or a late H1 will run with no battery installed.
PostPosted: Wed Sep 20, 2017 5:31 pm
I was asked by Jim to ship back the CDI to him. He tested it and it passed every test working flawlessly! Must have been a bad ground somewhere on my bike? Anyway, a big shout up and props to Jim for his excellent customer service! :thumbup:
RIP John E. Evans
PostPosted: Wed Sep 20, 2017 9:22 pm
disconnecting the ignition boxes and not draining that capacitors will kill the boxes if you refit and try to kick start, they somehow get double charged and blow the thyristor. .
A good ignition system will fire by removing the plugs and putting a 13mm wrench on the rotor and turning by hand, even a light kick with no plugs will / should produce a healthy spark
