It is currently Mon Jun 17, 2024 12:15 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Sep 15, 2015 10:25 am
Retro 3 wrote:
pierrot974 wrote:
HiWhere did you find that?
I use this :
:wave:
Now.... That's Cool! :clap:
PostPosted: Tue Sep 15, 2015 12:01 pm
If someone has one of those bowls around, put it on Ebay so I can pay too much for it.
PostPosted: Tue Sep 15, 2015 12:07 pm
Just spray one of your spares with clear coat, that's all he did... :e11
PostPosted: Tue Sep 15, 2015 1:41 pm
It's cool, but totally unnecessary. 30 seconds and a float is adjusted, BFD. :roll: ;)
PostPosted: Tue Sep 15, 2015 3:10 pm
Ideally, liquid level is the preferred method, but, only for carbs that sit in the engine level, not angled in any way.
That said, the carb should not be placed completely inverted to set the floats, the weight of the float itself can alter the setting by compressing the needle spring. The carb should be set on its side, with the float tang just hitting the needle spring plunger, minimum pressure from the float on the plunger, then, set the floats.
I use a modified Honda float bridge, a metal tool that looks like the one in the drawing on the resources page.
PostPosted: Tue Sep 15, 2015 3:50 pm
I do it like the factory, upside down, as the floats will also compress the spring also, so it is accurate.
PostPosted: Tue Sep 15, 2015 6:19 pm
We, at the factory, found a better way to hold the carb for float level checking, on the carb's side.
As to measuring liquid level, you don't need a clear plastic float bowl, a spare stock bowl will work just fine when modified correctly. inside the float bowl is a brass over flow tube. Remove it by simply pulling it out of the bowl. Then, on the bottom of the bowl where the over flow drain is, press a section of the over flow tube into it, and add a section of clear plastic tubing. To measure the liquid level, hold the carb straight up and down with the open end of the clear tube above the center of the carb, and add fuel through the fuel hose fitting. The fuel will seek its level in the clear plastic tubing. Adjust from there.
On adjustment, to each their own, do it as you please, but realize that some setups we read about as just plain too rich, haven't had any float level/liquid level adjustment and the fuel level inside the carb is just plain too high, causing the richness, no matter the jetting used.
On every G, A, S, H series, and 4 stroke Kawasaki carb I ever saw, the float levels were all too high from the factory, and when not set correctly, caused the engines to run between slightly, to excessively rich, until set right, especially when those carbs were Mikuni's. Yamaha and Suzuki had the same problems as well. Keihin's on Honda's were usually set very well.
PostPosted: Wed Sep 16, 2015 8:00 am
Great information, thanks Dave!
PostPosted: Wed Sep 16, 2015 8:12 am
Hi
First I do as says H2RTuner, carb on the side, not upside down.
And after, I control with my clear plastic bowl.
It is psycologic :lol: I can see the real level....... :mrgreen:
I am sorry Ja-Moo, but I don't understand the meaning of " BFD " :?:
PostPosted: Wed Sep 16, 2015 8:27 am
'Big ******* Deal' I guess, rather ungracious! :|
