It is currently Mon Jul 07, 2025 2:28 am
 Post subject: H1B rider to be...
PostPosted: Fri Jan 23, 2015 9:54 pm
This was my first Triple getting back into the "smoke" from way back in 2007, been sitting collecting dust since then, didn't "quite" sell to a fellow board member so at this point decided to start working on it to make it a rider sooner than later.
Though I've got all the EX brake parts to convert this, I decided to go the OEM dual disc route just because, and already purchased and/or received: caliper rebuild kits & dual hoses and lines from Amish John (I already have the correct splitter),
stainless pistons from hvccycle
Image,
those costly-when-added-up 4X caliper pin dust boots from z1enterprises,
RH caliper bracket kit from Leon http://www.kawi2strokes.com/forum/viewtopic.php?f=25&t=1082,
and I am going to try this all aluminum 5/8" m/c from mikesxs (It actually has the 5/8" raised mark on the underside of the body): http://www.mikesxs.net/product/08-6009.html
Hopefully the m/c works like the OEM Kaw equivalent that came with the dual disc kit. At $58.50 + shipping, it is alot cheaper than the original http://www.ebay.com/itm/171650246548 and a bit less than the repros from what I've seen available. :think:
 Post subject: Re: H1B rider to be...
PostPosted: Sun Jan 25, 2015 8:46 pm
:thumbup: Don't sell her
PostPosted: Sun Jan 25, 2015 9:52 pm
It doesn't look like it needs much - I love the patina.
PostPosted: Sun Jan 25, 2015 10:07 pm
Does that bikes engine run?
http://davestriples.com/
PostPosted: Mon Jan 26, 2015 12:42 am
It looks better in the pictures, but in person it's good enough for a rider as far as I'm concerned. I want to only focus on the mechanicals...speaking of which...VVVVVVV
"Ran when parked"... ;)
I'd rather not trust the crank seals or bearings Dave, so I was planning to come-a-knocking one day soon for a rebuilt, after I pull the motor and tear it down.
PostPosted: Mon Jan 26, 2015 12:47 am
How did it run then ?
PostPosted: Mon Jan 26, 2015 9:12 am
I like it, that's my favorite H1 paint job.
PostPosted: Mon Jan 26, 2015 10:04 am
I'll never understand why they decided not to give the H1 the same tail section as the S1, S2 and H2 for 72, that would make it even better for me... :? They even had 2 chances, B and C.
PostPosted: Mon Jan 26, 2015 11:06 am
I say we just put an h2 engine in that bike !
PostPosted: Mon Jan 26, 2015 12:26 pm
Smoke quite a bit from RH exhaust...
That's kind of my plan for a KH500 frame I've got (with factory gussets), and I even have late H1 rear sets, and H2 pipes that appear to be Figarolli that tuck nicely under the bike that I'd like to mount up to this as well...somewhere down the line.
