It is currently Mon Jul 21, 2025 11:12 pm
Post new topic Reply to topic  [ 153 posts ]  Go to page 1, 2, 3, 4, 5 ... 16  Next
 Post subject: 1972 Kawasaki H2 750
PostPosted: Sun Feb 21, 2021 6:05 pm
I got the bike a few weeks ago. So far I have removed most of the parts off the frame and started dealing with the engine. It has sat for 41 years with no attention. Fortunately the gas tank is in pretty good shape internally. Externally all the body parts will need a good paint job. The carbs took a bit of penetrating oil and gentle persuasion but are in good condition.
Seat cover is still good, but the foam is well on it's way to powder.
PostPosted: Sun Feb 21, 2021 6:56 pm
Whatever you do, don't install a carb rebuild kit!
PostPosted: Mon Feb 22, 2021 8:13 am
I will be most likely be installing one of Ivan's jetting kits. http://www.ivansperformanceproducts.com/h2.htm
I have known Ivan since High School. I believe him to be one of the best tuners. He spends a great deal of time getting bikes running at their best.
Unfortunately he moved from the area, so I will not be able to stop by his shop anymore.
PostPosted: Mon Feb 22, 2021 8:27 am
Fortunately I was able to get the pistons and cylinders removed. It took a lot of penetrating oil, time, and effort to get them off.
The new Wiseco pistons and rings are off to the machine shop with the cylinders and heads.
Cleaning up the engine and frame underway while I await their return.
PostPosted: Mon Feb 22, 2021 8:43 am
Yes, Ivan's jet kits are good. I don't put them in the category of all the horrible rebuild kits that are on the market. But why didn't you go with Wossner pistons?
PostPosted: Mon Feb 22, 2021 10:27 am
What's wrong with Wiseco? You can get them for $100 less per set and they are good quality!
PostPosted: Mon Feb 22, 2021 11:05 am
Interesting. I didn't know that their price had gotten lower than Wossner. Do you know if they have solved the skirt collapse problems of past decades?
PostPosted: Tue Feb 23, 2021 7:45 pm
Wiseco needs to be set up.way too loose.
PostPosted: Tue Feb 23, 2021 8:26 pm
I get the impression that their manufacturing techniques have changed since those days, but I don't know for sure.
PostPosted: Wed Feb 24, 2021 10:40 am
Nope, same dismal stuff, and too much bore clearance.
Wossner is the better product than Wiseco, by far.
