There are seals and there are oil receivers. I'm guessing you are talking the oil receiver. Most are worn out anyway and are not available as far as I know. they are there to direct the oil going to the bearing into the big end pin and to the big end bearing. It is really not a big deal if you have slotted rods. That written, many guys haven't had problems, so I can only say if you aren't a crazy rider with long bouts of WFO for miles, you should be ok.
Are you saying that the crank oil receivers are not available and when anyone rebuilds a crank they don't bother putting them back on? And there are no repros or aftermarket ones either? This is an important part that makes the oil injection worth the time and effort, direct oiling to the big end.
