It is currently Tue May 21, 2024 9:48 pm
PostPosted: Wed Dec 07, 2016 10:40 am
Anybody have a source for the H2C pushrod seal, part number 92050-070 NOK AC0094F
PostPosted: Wed Dec 07, 2016 12:13 pm
They are hard to find, and if you do find them they are usually hard as rock. No aftermarket available for this one.
I just recently I devised the following method which is useful if you already have the engine apart:
I turned a step in the clutch rod bush (2.5mm wide and down to Ø27mm) which will fit inside the standard seal. This will provide enough clearance to use the ball bearing release together with the standard seal (92050-025).
PostPosted: Wed Dec 07, 2016 12:40 pm
that's a tidy solution :thumbup:
PostPosted: Wed Dec 07, 2016 3:53 pm
Repo,s are available from Webike $8.55 plus shipping
http://japan.webike.net/products/2161220.html
PostPosted: Wed Dec 07, 2016 4:30 pm
Cool... About time they started making that one.
PostPosted: Wed Dec 07, 2016 6:25 pm
John I looked through all my purchases last 5 years (I know I replaced mine). I can't find the individual seal purchase but I've bought several seal kits that have the clutch oil seal in it. Now I know the differences, my early nylon was cracked and I found a bearing one but had no reason to open the casing at the time - so I made a spacer.
When I did open it a few years ago I replaced it with the 92050-070 that I'm pretty sure was in the seal kit. In fact I just checked Larry's site at mid-atlantic and repo and they both have the newer -070 seal in it. Finding a individual one - seems difficult.
I don't now about finding the older -025 ?? :roll:
Info from the old site that I don't think made it over - furture thread searches. Plus MRAXL has some good info too.
If you are using a Ball Bearing Actuator the correct seal is 92050-070.
Currently all of the aftermarket engine seal kits come with the 92050-025 seal.
All clutch releases are interchangeable. However, the ball bearing release must be used
with a 92050-070 seal or spaced out to prevent seal destruction in the H series.
PostPosted: Thu Dec 08, 2016 2:18 pm
Thanks for the replies. Very slick mod PK!! Sure enough I just searched ebay and Webike has the -070 seals brand new. Im going to order a couple! The sudco kits come with the -025 seal if you order an H2 kit.
PostPosted: Thu Dec 08, 2016 10:06 pm
They remanufactured them by the thousand 5 Years ago, they should be readily available :thumbup:
PostPosted: Fri Dec 09, 2016 1:19 am
I bought mine from purple haze
