It is currently Sun Jul 06, 2025 5:52 pm
 Post subject: Caliper rebuild
PostPosted: Thu Feb 26, 2015 12:34 pm
X
Last edited by warehouse1001 on Mon May 15, 2017 10:56 pm, edited 1 time in total.
 Post subject: Re: Caliper rebuild
PostPosted: Thu Feb 26, 2015 1:46 pm
Theyare so inepensive on the used market I would suggest buying another for a rebuild (assuming the cylinder is OK.
Replacement pistons are now available.
PostPosted: Thu Feb 26, 2015 1:49 pm
That is probably your best bet Chuck.
Buy a used one in better shape at evilbay.
Going to Ricks this August?
PostPosted: Thu Feb 26, 2015 2:15 pm
Yes, I have. I do it the way a company maned 'Vette Brakes" does it, with a heat set, pressed in stainless steel insert. A good machinist should have no problem doing the install and parts manufacture, the key is to get the heated press clearance/function correct, so the sleeve stays in place without issues.
Of course, one very important thing, though, if you, or, your machinist do not have adequate machining experience/ability, accurate machines to do this work right, PLEASE do what the others have recommended, find a better caliper to use that doesn't need re-sleeving.
